Can someone help indentify this ls1 cam?
Old May 28, 2009 | 11:07 PM
Jose93z28's Avatar
Default Can someone help indentify this ls1 cam?
Hi my friend has a ls1 cam with the following numbers on it ls1 3316/3317 hr114 , followed by t3809 on the bottom, he wants to find out what it is, please let me know if you guys have any idea thanks.
Old May 28, 2009 | 11:37 PM
5.3LJimmy's Avatar
That looks to be a Comp Cams 236/242 .590/.612 114LSA.
Old May 29, 2009 | 06:57 AM
SweetS10V8's Avatar
Here is where 5.3LJimmy and you can find that information....
http://compcams.com/Technical/Catalo...obeCatalog.pdf
Old May 29, 2009 | 08:07 AM
Jose93z28's Avatar
Thanks for the info guys.
Old May 29, 2009 | 09:05 AM
5.3LJimmy's Avatar
That's where I got the information from. But those lobe numbers are listed under the regular XE and not the LS1 specific XE lobe chart.
Old May 30, 2009 | 01:03 PM
LS1MCSS's Avatar
Post a picture of that cam, or just check for a distributor gear at the back of it. Those lobe numbers are for a SBC.
Old May 30, 2009 | 11:15 PM
Jose93z28's Avatar
Thats kinda weird, and it doesn't have a dist gear on the back at all.
Old Jun 2, 2009 | 11:24 PM
Jose93z28's Avatar
Do you guys know if my friend can run this cam in a 6.0 truck? if so would it be an ok cam for forced induction or nitrous, and what kind of springs does he need for this cam ? thanks for your help in advance.
