Valve seal recommendations
Old May 30, 2009 | 04:04 PM
Steve Gunn's Avatar
Default Valve seal recommendations
I have all the symptoms of "f"d up valveseals and I'm going to replace them. Right now, I have the ones patriot gives you with the gold spring kit on the car that someone else assembled.
What are the best seals to get, GM(different intake/exhaust pn#'s) or some aftermarket?
Do I really need the expensive fbody low profile spring compressor?
I've read all the "how to's". Just looking for some opinions...
Thanks!
Old May 31, 2009 | 12:55 AM
WhiteRhino's Avatar
The GM ones are actually quite good. Patriot sells them for a buck 25 a piece on their website. Those are the ones I always use. https://www.patriot-performance.com/...ome.php?cat=51
Old May 31, 2009 | 06:31 AM
vettenuts's Avatar
GM seals are tops, fit well and seal well. As for the compressor, someone on here rents the Crane if you don't want to buy one, but for an f-body with those difficult to access back cylinders it is the right tool for the job.
Old May 31, 2009 | 07:49 AM
Steve Gunn's Avatar
Thanks, guys!
Old May 31, 2009 | 08:32 AM
JFM-jr's Avatar
Are these the ones with "NOK" on them?
