Weird oil pressure
Now when my last unit went out it started fluctuating real crazy, from 20psi @ idle, up to near 70 at 2-3k rpm, and 40psi on the hwy. After I shut the car off, and fired it back up, the guage would read -0, like a dead gauge, then after 2-3 minutes of it running it would jump back up to normal for about 5 minutes, then go back to fluctuating until I eventually turn if off. Repeat cycle.
Is there a problem with my new unit? For the month's time it's been in there, I've had no problems, and a solid 40+psi reading from idle. Now it's back to fluctuating which makes me think it's the unit again. Could it be a connection problem or something?
I thought it may be my pump (stock 65k mile), but that wouldn't explain the month's worth of good psi readings immediately after the sending unit swap, and now back to being funky.
Thanks for any input.
