Should I replace my oil pump?
).Anyway, is it a good idea to replace the oil pump along with the water pump?
I have replaced a water pump before but never an oil pump... I have read the guide and have no idea if it is something I should attempt or not.. Although the amount of labor a shop will charge is probably insane...
Anyways thanks for any help you can offer...
Oil pressure is fine now in my opinion. From cold start usually around 50 and up to 60 or a lil over at mid rpm.
Although it is summer time now and I have noticed a little drop in pressure as I get off the interstate. It dropped to about 30 today at the off ramp red light.
^ could have been because AC was on tho. That seems to drop it a little.
((Also I am using mobile 1 syn 10-40...))
