ported ls6 pump only 48 psi wot!
Old Jun 1, 2009 | 06:47 PM
STAR's Avatar
Default ported ls6 pump only 48 psi wot!
Hey guys, need some suggestions and opinions on what I should do. I have a fully built forged motor and I'm using a ported and shimmed ls6 oil pump. At cold idle I see 49 psi pressure and 220 degrees hot I see 24 psi at idle. Problem is oil pressure does build with rpms, but maxes out at 48 psi at anything over 5000 rpms. This scares me as I want to pull the motor to 6500-6800 rpms. Why does the pressure not increase anymore? Any suggestions?
Old Jun 1, 2009 | 07:09 PM
dre2013's Avatar
o-ring seated properly? and have you verified these numbers on a mechanical gauge? my stock oil pump with 140k on it holds 40psi warm idle..
Old Jun 1, 2009 | 08:43 PM
Marc 85Z28's Avatar
While you may still have a problem, 48psi is plenty of pressure for 7000rpm. 24psi at idle is also more than adequate.
Old Jun 1, 2009 | 08:57 PM
bigboykilroy's Avatar
I use the old rule of 10 psi per 1000.
I love my meling pump.
Old Jun 1, 2009 | 09:14 PM
98Aggie's Avatar
Moderator
Is this a new motor - never run before?
What are your bearing clearance set at?
Old Jun 1, 2009 | 10:06 PM
STAR's Avatar
Yes its a new motor that has about 600 miles and everything seems fine. I think the mains are at .002 and the rods at .0025 if memory serves me corrrect.
Considering upgrading to a melling 296 pump.
Old Jun 1, 2009 | 10:07 PM
05 GSXR 1XXX's Avatar
pinched o ring?
Old Jun 1, 2009 | 10:09 PM
SweetS10V8's Avatar
Key word is old, almost a wives tail now.... You dont need anywhere near 10psi/1000 RPM.
This engine has plenty of pressure to survive. Doesnt mean there isnt anything wrong, but doesnt mean that there is either....
Old Jun 1, 2009 | 10:30 PM
STAR's Avatar
Don't know if the o-ring is pinched until I take it apart, but I doubt it. It seems like I'm bleeding off pressure somewhere? Or just simply the oil pump is not providing enough volume?
Old Jun 1, 2009 | 10:33 PM
I wouldnt run an engine at 7000 with 48psi, go with the Melling 10296 Oil Pump.
also make sure the oil pressure sending unit isnt damaged, test the pressure with a mecanial reader to be sure of the pressure.
Old Jun 1, 2009 | 10:39 PM
actually after thinking,,,,,if it wont build pressure over 48 psi i bet the pressure blead off spring is defective (in the oil pump)
mechanical test then order a Melling 10296 Oil Pump to replace it.
Old Jun 2, 2009 | 09:43 AM
muayyadf1's Avatar
try to change oil + filter
Old Jun 2, 2009 | 10:03 AM
Yes I forgot about that as well, if its a fram get rid of it !!
I only use Napa gold (Wix)
Old Jun 2, 2009 | 07:47 PM
SweetS10V8's Avatar
You would be surprised how bad things have to be for an engine to die. 3v fords only have about 35psi at 7000 RPM.
Ive also run ZZ4s to 7000RPM at 25psi and never had a problem, even tore apart the bottom end and all the bearings looked perfect.
I would find out if indeed it is possible to have a mechanical bleed off, or if something is wrong causing it to bleed.
Old Jun 2, 2009 | 07:58 PM
Super Speed's Avatar
Try running a thicker oil if you want more PSI...
Old Jun 2, 2009 | 08:01 PM
Breathing Fire's Avatar
Try the easy stuff first. Change oil and filter. I used a fram once because my usual ac delco was out of stock that day. Lost 15psi of oil pressure. Fram=****!
Old Jun 2, 2009 | 08:06 PM
I use a WIX filter!
Old Jun 2, 2009 | 08:13 PM
ehnihl's Avatar
I use a WIX filter too...
Old Jun 2, 2009 | 09:29 PM
01formula6's Avatar
And I've spun a bearing running a ZZ4 to 5500 with only about 15-20psi...just saying. I don't trust things when oil pressure gets that low.
Old Jun 2, 2009 | 09:43 PM
SweetS10V8's Avatar
Im not disagreeing, Im just saying 48psi isnt that low...
