Nitrous/Turbo cam
Old Nov 7, 2003 | 05:08 PM
DD966's Avatar
Smile Nitrous/Turbo cam
I'd like to replace my stock cam, ONCE!!! Down the road, I 'may' purchase a turbocharger (sts, if trials are good) or NOS (probably 5177 kit). I'll replace my cam before that. Is there a cam that's suitable for both? Unlike some of you mad-scientists, I don't want to go messing around in there more than once. Thanks for your input.
Old Nov 7, 2003 | 05:11 PM
H82BBad's Avatar
2 different types of cams.
Old Nov 7, 2003 | 09:27 PM
z98's Avatar
z98
Replace the cam when you decide.
Old Nov 8, 2003 | 06:08 PM
SStrokerAce's Avatar
Both of those cams are completely different.
They both also depend on alot of things.
On a turbo cam if you can balance the backpressure of the exhaust manifold with the boost pressure than you have a different cam from one that's unbalanced. Usually it's a smaller than normal camshaft vs a NA application.
A N2O cam usually likes more duration so he small turbo cam is not even close. That and a N2O cam likes alot of advance most times too.
Now you also want a NA cam on top of that, again big difference.
A N2O cam and a NA cam can be very close so that's not a bad idea.
Bret
Old Nov 9, 2003 | 04:00 PM
Noyzee's Avatar
8 second mod
hold off till you decide on power adder.
like said befor N2O/NA like bigger cams, and turbos would benifit more with a set of good heads, but a small rev split cam would prob be best.
