Nitrous only???
Old Jun 6, 2009 | 12:14 AM
99 ls1 z28's Avatar
Default Nitrous only???
I have 4.10's, pacesetter LTs, cattless y-pipe, 3" exaust, chrome alloy push rods and 70,000 thousand miles i just bought a nx wet kit and i want to put a hundred shot on the car and it will be dyno tuned very well by a professional is that going to be really hard on my motor if i dont spray on the street all the time??????? the juice is mainley for the track but i cant say that im not going spray on the street once in awhile it will be a window kit that will engage at 3000 rpm and disengage at 6000 rpm any suggestions?????????????????
Old Jun 6, 2009 | 12:21 AM
Y2KblueZ-28's Avatar
As long as the car is tuned for it you should be fine, just make sure to run a colder heat range plug like a ngk tr6 plug . Thats the plug i run in my car with a 100 shot , but im going to warn you pushing that button gets addictive
Old Jun 6, 2009 | 12:23 AM
99 ls1 z28's Avatar
its throttle controled its not a button but no doubt i only have a 10 pound bottle tho so i cant hold much and will only refill at the track once a week or twice so i should change my plugs too?????
Old Jun 7, 2009 | 01:13 PM
99T/AMAN's Avatar
yeah they reccomend running ngk tr6 plugs when running nitrous
Old Jun 7, 2009 | 01:15 PM
Fbodyjunkie06's Avatar
Colder plugs are a must, some will say hardened pushrods are too...you've got 1 of 2 prerequisites have at it once you get those plugs!
