03 lq9
Old Jun 7, 2009 | 06:44 PM
63falcon's Avatar
Default 03 lq9
So i picked up an 03 lq9 complete minus coil packs for a good price. Problem is it spun some rod bearing and some of the mains. Question i have is can you find the stock lq9 rods and crank pretty cheap or am i kind of screwed just looking to do a pretty bone stock cheap 6.0 turbo setup dont want or need anything fancy any info would be greatly apreciated on which route i should take. Thanks Brian
Old Jun 7, 2009 | 09:28 PM
sroach20's Avatar
5.3, 5.7, and 6.0 iron have the same cranks. just watch the classified section and youll see them going for cheap.
Old Jun 7, 2009 | 11:40 PM
63falcon's Avatar
cool thanks
Old Jun 7, 2009 | 11:59 PM
sroach20's Avatar
make sure you get it re-balanced.
Old Jun 8, 2009 | 12:34 AM
elias_799's Avatar
i am not sure the 5.7 crank and the 6.0 crank is the same. i think the reluctor wheel on them is different. not 100% sure but i am sure somebody will chime in.
Old Jun 8, 2009 | 08:39 AM
sroach20's Avatar
same, just has holes drilled in it.
