Eagle stroker crankshafts?
Old Nov 15, 2003 | 07:34 PM
  #61
XLR8NSS's Avatar
Adkoonerstrator
Originally Posted by Solid346
opps my bad, i thought they designed the crank only for 6.1 rods.. i alreday have the pistons made for 6.125 rods and i already got the rods for it.
i guess i will wait to see how much will it be..
hhmm 383ci Solid Roller .. sounds wicked
One other thing. The pistons must be designed for a 4" crank. If the pistons you have are made for a stock stroke they will not work with the 4" crank. The pistons are the part that need to be made for whatever stroke and rods you'll be using.
Old Nov 15, 2003 | 07:43 PM
  #62
99 Black Bird T/A's Avatar
I want to hear what a machinist has to say about this crank before getting overly excited. Sometimes new Eagle cranks have been tappered on the journals etc. A lot of extra machining required to balance/machine cranks properly that has issues like that. I hope the LS1 stroker cranks will be a lot better
Old Nov 15, 2003 | 09:30 PM
  #63
Aidan's Avatar
Yes...jobber is wholesale , racer net is MSRP, expect most shops to sell them for somewhere in the middle between jobber and racer net
Old Nov 15, 2003 | 10:07 PM
  #64
NA$TY-TA's Avatar
PM sent
Old Nov 16, 2003 | 12:26 AM
  #65
VSGLS1's Avatar
I have been thinking of my next setup, now this is some good news. I think a stroker will be in my future.
Old Nov 17, 2003 | 06:55 PM
  #66
NA$TY-TA's Avatar
Ordered mine.......... Blown 383 here we come
Old Nov 18, 2003 | 01:07 AM
  #67
SSDude's Avatar
This is good news. What will the prices be for a 382-383 stroker kit and for a 427 stroker kit?
Old Nov 18, 2003 | 05:53 AM
  #68
Aidan's Avatar
Sold nasty TA a 383 kit for $2000. 427 kit is same price and so would a 408"
Old Nov 18, 2003 | 06:25 AM
  #69
VortechC5's Avatar
What all are you including in the kit? That's a really nice price!
Mark
Old Nov 18, 2003 | 08:46 AM
  #70
Heretic's Avatar
I have heard that Eagle uses forgings from China, then finishes them here.
True?
Old Nov 18, 2003 | 08:55 AM
  #71
Vents's Avatar
who cares if they do? they still work great.
Old Nov 18, 2003 | 12:03 PM
  #72
NA$TY-TA's Avatar
Aidan and I are using the same setup except he is going to use an Iron block. What i got from him was an Eagle 4" crank, Crower rods with ARP rod bolts, Diamond boost piston for 8.5:1 comp, diamond rings, and rist pins for $2000. I also got ARP mains. Vince give me a call today.
Kyle
Old Nov 18, 2003 | 12:53 PM
  #73
LS1x2's Avatar
Formerly 4mulaJoe
I just finished doing a 348 and now I want to puke. Could have built a damn stroker.
Old Nov 19, 2003 | 02:03 AM
  #74
SSDude's Avatar
Kyle
Does it have to be balanced?
Old Nov 19, 2003 | 02:12 AM
  #75
Scott Turvey's Avatar
You might depending on the Rockwell # of the metal. Historically Chinese rods & cranks have been rather brittle relative to US forgings. Not a problem 'til you start rattling the motor (RPM's/Nitrous)
Old Nov 19, 2003 | 02:24 AM
  #76
Cal's Avatar
Cal
Kyle
NA$TY, Why did you go for the 383 kit when you could have had the 427 for the same price?
Old Nov 19, 2003 | 02:39 AM
  #77
Originally Posted by Cal
NAS$Y, Why did you go for the 383 kit when you could have had the 427 for the same price?
Probably because he would have to add the expense of a C5-R block or a sleeved block to get the 427 inches? "383" or close to it would be with stock liners and a 4" crank only.
Old Nov 19, 2003 | 03:22 AM
  #78
verbs's Avatar
The 383 is $2000 for the entire kit w/o install....and he can retain use of his current heads if he desires.
A 427 is $4000 minimum just for a basic shortblock, and that doesn't include the new heads he'll need....so tack on another say $2000-$4000 depending on how crazy he'd want to get.
Old Nov 19, 2003 | 09:50 AM
  #79
NA$TY-TA's Avatar
Thanks Verbs. That is exactly why i did it. The other option was to go with an iron block. I have been fighting it over in my head and i decided i didnt want to add the wight after all. what was the most important thing to me..... strength. I wanted to be able to run more boost then i am now and not have to worry. The pig also weighs 3834 with me in and no weight reduction. With the seats all out including the passenger i got ot down to 3640. Who likes to drive like that all the time?? Not me. When i go to the track yeah. It really has to do with your goals and how much $$$$$ you have to play with. Just like Scott Turvey said above you can use the stck liners. All i need is a clean up hone of .007 and then all new bearings and have a machine shop put it togeather and make sure its all balanced and throw my heads on and basiclly i have a new motor. Hope this cleared up all the questions. My kit will be going in as soon as the parts get shipped and get to me.
Kyle
Old Nov 19, 2003 | 10:00 AM
  #80
Cal's Avatar
Cal
OK thanks for clearing that up. Sounds like a bargain! How much boost are you running now?
