Sleeper setup idea!
Old Jun 23, 2009 | 07:44 PM
allblacksrt4's Avatar
if you are talking about a street racing sleeper. the gym bag idea has been done a million times. 5lb bottle in dash and a dry kit. i wont tell you where to put it but there is somewhere that will never be found. Also the first thing they will look for is nitrous and then rear end. easy count the bolts.
Old Jun 26, 2009 | 04:21 AM
krazy4's Avatar
Originally Posted by Bird_Of_Prey
Just remember, you're pretty much busted out the first time you make a pass and trap 125 in a stock car. A hidden dry setup is much better suited for little love taps when you need it. Wet kits don't like on/off/on/off/off/off/on
Don't wanna do a dry kit and have bigger injectors that someone could see.
Originally Posted by Patrick G
This setup is very similar to my Trans Am from a few years ago. It was a very fun project. The gym bag with nitrous is definitely an old street racers trick. Many a competitor fell prey to the "bag of nitrous". You should have a blast with it.
Gym bag of win lol.
Yeah, I am surprised more people don't know about it haha.
Old Jun 26, 2009 | 05:56 AM
james562's Avatar
You could also make a bracket and run the bottle under the rear bumper if you were to take the support out.
Just pray no one ever rear ends you.
Or ditch the door bars and run one 5lb bottle in each door.
**** I bet I could fit one under the passengers side dash and it would blend it if i carpeted it on the visable side
Old Jun 26, 2009 | 08:17 AM
nastychevelle's Avatar
you could build a 383 put ported 243's on top and a fast intake ground and painted to look stock
Old Jun 26, 2009 | 03:24 PM
krazy4's Avatar
HAHAHA, that would definitely work though. I don't know, i just like the gym bag for the simplicity.
Cmon man, camaros didn't come with 243 heads lol.
Old Jun 26, 2009 | 03:32 PM
sure they did its one of those NEW things
Old Jun 26, 2009 | 03:33 PM
transaman98's Avatar
seems to me I read an acticle about a mustang putting little 5lb bottles in his doors and running the lines through existing stuff in the car. Even the techs at the track couldn't figure out how he was breaking out of his class. Thats really sleeper!
Old Jun 26, 2009 | 04:18 PM
Bird_Of_Prey's Avatar
No matter how much you grind an paint, a FAST intake will NEVER look stock.
Old Jun 26, 2009 | 04:58 PM
james562's Avatar
Thats the idea I was talking about, I think he ran all the lines along the path of the speakerwires and covered them in loom. Just pop the speaker grills off and open the bottles and you'd be set!
Old Jun 26, 2009 | 05:13 PM
thats the one! when I read that article I had all kinds of ideas! Just imagine how much fun you could have with a setup like that. Put remote openers in there and wire them up to a switch that is already in the car and then you are really talkin!
Old Jun 26, 2009 | 05:21 PM
90mm modded ls6 then
Old Jun 26, 2009 | 05:42 PM
  #32
GreenbeanZ28's Avatar
the Compucar nitrous in a bag kit has very little braided line. The solenoid is basically straight off the bottle, everything after the noid is tiny black vacuum looking line. There is no nozzle to speak of, just a brass fitting with a metal tube coming off that can be angled to wherever the MAF likes it the best. No crazy electrical stuff either, it comes with a cigarette lighter plug in and a button. I've had 2 of these kits in the past on my old Camaro, nobody ever found it. Had the bag behind the seat where I could just reach back and open it. I usually tossed in a shirt/short/socks to help camo it, if someone were to take a quick look.
Old Jun 27, 2009 | 07:17 PM
  #33
krazy4's Avatar
LOL, that would be sick as hell!
Old Jun 28, 2009 | 08:19 PM
  #34
FormulaZR's Avatar
Speaker box, subs, amp...and a large power wire/nitrous line...
Old Jun 28, 2009 | 09:33 PM
  #35
ramdaspadhye's Avatar
Just put a turbo on it... It'll be sleeper....til boost kicks in
Old Jun 29, 2009 | 07:03 AM
  #36
slt200mph's Avatar
The modded TPIS 90mm LS6 intake uses an oval throttle body and looks nothing like a stock throttle body/intake.
Old Jun 29, 2009 | 08:14 AM
  #37
1969mach1's Avatar
That was in Muscle Mustang & Fast Ford. they installed the bottle in the pass door, the solenoid was installed inside the cowl panel, and a nylon tube "painted black" was routed through the back of the vacuum distribution block that mounts to the fire wall and ran the nylon tube through a factory vacuum hose to the back of the intake. The nylon hose acked as the jet, it has around 165-170hp shot dry.
Old Jun 30, 2009 | 02:17 AM
  #38
krazy4's Avatar
Not to hard to find a turbo
Old Jun 30, 2009 | 05:28 AM
  #39
LustrousWS6's Avatar
If I was gonna race said car, the slicks would scare the ***** outta me and while racing if I noticed the thing never shifted into 4th I'd really start getting suspicious (assuming the race went long enough).
Old Jun 30, 2009 | 12:20 PM
  #40
383lt1impala's Avatar
Why not go hi compression, ms4 or bigger cam, ported heads etc etc??? Lol
