heads and cam install
Edit: This will present a problem if you're using Head Studs like I did. There was not enough room to put the heads on with the headers and the studs in place. I ended up seating the heads, then putting the studs in - BUT the passenger side bottom back two were too long to fit in. I resorted to using GM head bolts for the two holes I couldn't get the studs in.
Take out all the pan bolts except the last two (leave them in enough so they're still threaded). The tray will drop down enough to do it, although it's not easy. Take the necessary precautions to not drop the bolt into the pan (I stuffed a Ziplock bag in and let the bolt fall into the bag).
Good luck!
