Wont Start Help!
Old Jun 30, 2009 | 05:18 PM
2002 SS's Avatar
Default Wont Start Help!
i just got done my H/C install but when i went to start it it wont fire up. i installed LS6 oil pump, MS4 cam/LS6 Ported heads, 30# SVO injectors, UD pulley. im wondering if the injectors is just washing down the cylinders because for now im on stock tune. i pulled the valve covers and the see the rockers moving so i know the cam is turning.... any help would be appreciated thanks
Old Jun 30, 2009 | 07:14 PM
dre2013's Avatar
you need a tune..esp with those injectors. you r risking washing down your cyl walls.
Old Jun 30, 2009 | 07:30 PM
2002 SS's Avatar
you think thats y its not starting? its turning over but not firing..... while its trying to start theres like a thumping sound coming out the headers guessing the cam is turning but no action... thanks
Old Jun 30, 2009 | 08:33 PM
Lt1Porsche's Avatar
Its not easy to miss but ya you need to make sure u got everything lined up right.
Old Jun 30, 2009 | 08:46 PM
2002 SS's Avatar
nope cant be the injectors i just swapped stock back in and still no start. only very little white smoke coming out the intake. do they sell a tool to assure that the cam is aligned straight dot to dot?? i just played it by eye
Old Jun 30, 2009 | 09:34 PM
2002 SS's Avatar
BTW could the car not start if the dot to dot isnt dead on center? i think im gonna have to tear back into it...
Old Jun 30, 2009 | 11:00 PM
2002 SS's Avatar
Jus opened my timing cover and it reaks of gas! also while jacking up the front of my car gas was coming out my headers(open headers).... could it be that it just wasnt starting because it was being washed down with wayy to much gas? also if i hand turn the motor and it only turns so much before it locks up...does it mean that the cam is installed wrong?? thanks!
Old Jul 1, 2009 | 10:03 AM
EDS01SS's Avatar
sounds like your not getting any spark either. make sure all your grounds are hooked up on the back of the drivers side head
Old Jul 1, 2009 | 01:19 PM
2002 SS's Avatar
also the plugs were covered with gas so obviously it couldnt give any spark anymore. the only way the motor turns by hand is if i loose the rockers (guessing thats bringing the valves back up)... could this be a sign of PTV issues?
Old Jul 1, 2009 | 06:58 PM
2002 SS's Avatar
i tore it all apart and made sure timing was correct and still making thumping sound at start up .. how can it be PTV clearance when i have the MS4/LS6 stg.1 head combo from TSP?
Old Jul 2, 2009 | 05:59 PM
crainholio's Avatar
Talk it over with TSP, see if they've had cases where the piston crowns had to be clearanced. Also ask about pushrod length requirements.
Old Jul 3, 2009 | 12:08 AM
elias_799's Avatar
first i would take out all the spark plugs and disconnect all the injectors. then crank the motor a couple of times to get rid of some of the gas that is in the cylinders, then throw everything back together (new spark plugs preferably) and try starting it.
Old Jul 3, 2009 | 12:12 AM
2002 SS's Avatar
thanks for all the tips guys! BTW if i broke my coolant temp sensor on the head would that cause it to not fire?? and i did a search and read everyone talking about the cam/crank sensors.. i didnt notice any sensor on neither of them. can someone help me out, this was my first swap and now im starting to freak lol. thanks for your help!
Old Jul 3, 2009 | 12:23 AM
elias_799's Avatar
the cam sensor is in the back of the motor beside the oil pressure sensor
i believe the crank sensor is behind the started on the engine block if i remember correctly.
Old Jul 3, 2009 | 01:01 AM
2002 SS's Avatar
oh ok thanks. so i didnt take out those sensors.. thought i was goin blind lol. like i asked above... could it just be because i have a broken coolant sensor on the head be the reason why it wont start at all?
Old Jul 3, 2009 | 03:28 AM
DaddySS's Avatar
You can't just stick new injectors in there without adjusting for them. Take the plugs out and with everything else hooked up turn it over by hand to make sure it turns freely. If it does, make sure you have the original injectors in, put in new plugs, make sure all your connections are tight and correct and fire it up. The temp sensor will not stop it from starting.
Old Jul 9, 2009 | 01:47 PM
2002 SS's Avatar
could i start the car with the injectors and plugs out to get rid of some of the gas??
Old Jul 9, 2009 | 01:58 PM
ds98formula's Avatar
Pull the fuel pump fuse, take the plugs, out and turn the engine over a couple times the gas will come out the spark plug holes. It sounds to me you are not getting spark go over eveything really good and double check your grounds. Good luck
p.s if you do get it started change the oil right away, alot of the extra gass will end up in the oil.
Old Jul 9, 2009 | 03:58 PM
ineedamotor's Avatar
what he said above me.. thats what id do at least
Old Jul 9, 2009 | 04:07 PM
joecar's Avatar
Looks like your injectors are "leaking" badly... I suspect your injector harness is shorted to ground keeping the injectors on all the time... (or maybe your PCM is bad... I don't think it is...).
If the crank sensor was bad then the injectors (and the spark plugs) would not fire.
