Checking valve pattern why do u need a soild lifter ?
Old Jul 1, 2009 | 09:28 AM
BigRich954RR's Avatar
Default Checking valve pattern why do u need a soild lifter ?
Ok when checking the valve tip/rocker wear pattern why do u need a solid lifter ? if it compresses a little whats it matter your going to compress it with preload anyway
Old Jul 1, 2009 | 10:52 AM
JPH's Avatar
JPH
Use a "soft spring" in place of your valve spring and it will work fine.
Old Jul 1, 2009 | 11:17 AM
vettenuts's Avatar
If the pushrod compresses the lifter, two things result. First, you lose some lift and as a result shift the pattern to the intake side. Second, you need to be at zero lash when you do this otherwise the results are skewed.
Old Jul 1, 2009 | 11:58 AM
Damian's Avatar
LSX Mechanic
What he said.
On a setup where i'm not pulling the heads, I use a very soft spring. Of course if the heads are off, a solid lifter is used.
