Just ordered some heads. What gaskets to get though?
Old Nov 13, 2003 | 02:39 PM
Ryan23silverado's Avatar
Talking Just ordered some heads. What gaskets to get though?
Just ordered some LS6 heads from Texas Speed and Performance
I have a question though...What head gasket should I use if it is going on a 5.3L truck engine? TexasS+P said to use the graphite gasket. I heard the Multi Layer Steel gasket was the way to go though. Is there some difference between the 5.3L block and the LS6 heads that I need to use the graphite gaskets? (I thought I read something about a coolant passage???) Which head gasket of those two (graphite or MLS) would be best for boost?
Thanks for clearing that up
Old Nov 13, 2003 | 02:44 PM
gomer's Avatar
I've used both. I used the steel shim ones this last time since they were a little cheaper. Both of them are good gaskets. Congrats on the heads! What cam are you going to run?
Old Nov 13, 2003 | 02:54 PM
strokedls1's Avatar
Cometic and gm both make an mls head gasket. Cometic has had problems with leaks on some cars though. The FelPro's are a good choice, and are only like 22 a piece from autozone.
Old Nov 13, 2003 | 03:16 PM
Thanks for the replies guys. So should I get the graphites for a 5.3L or in a 5.7L bore size. I was thinking 5.7L (99mm bore) since they are 5.7L heads. Does that make sense?
Gomer I will be running a small cam for those heads (the '02 LS6 cam) I am boosted though, so these heads should allow me to run tons of unrestricted boost. I went low on the duration for easy tunning and driveability. oh yeah the cost was 1/2 that of a Lingenfelter GT-2 cam also
Old Nov 13, 2003 | 03:27 PM
Nasty N8's Avatar
Ya I would put on the 5.7L gaskets to matck the chambers in the heads.
Nate
Old Nov 13, 2003 | 03:49 PM
Damian's Avatar
LSX Mechanic
Get the multi layer aluminum gaskets. If you ever have to pull the heads for some reason, they are a LOT easier to deal with. Practically ZERO cleanup. If you run graphite, you'll spend 2 hrs scraping that crap off the block if the heads are ever pulled again. You never know whats going to happen, so i'd run the lower maint. gasket. JMO
Josh
