oil in intake??
Old Jul 2, 2009 | 02:42 PM
cominupSS's Avatar
Default oil in intake??
ive noticed here latley that i got a little bit of oil in the intake....i changed out the PCV valve but its still their any ideas? thanks
Old Jul 2, 2009 | 02:47 PM
SOMbitch's Avatar
Very common.
Go to External and search catchcan..
Old Jul 2, 2009 | 07:11 PM
eamador11's Avatar
you need a catch can from Norris Motorsports
Old Jul 2, 2009 | 11:46 PM
elias_799's Avatar
^^^ if you have money to burn go ahead. and you will still have some oil in your intake with a catch can.
if you want absolutely no oil in your intake then block off all the pcv lines and install a breather on the valve covers. much cheaper and better then a catch can.
Old Jul 3, 2009 | 10:54 AM
black01_WS6's Avatar
if you put breathers on you need to have one on each side to do it correctly.
I put in the updated PCV valve from WS.6 store, and a catch can and I no longer have any oil in the intake, has been like that for over 2 years now.
Old Jul 3, 2009 | 08:56 PM
elias_799's Avatar
^ no you dont. if you have an na motor around 400whp 1 breather is all you need.
