Plz help car won't start,ZERO codes!! Video in..
We also replaced the Fuel pump relay under the dash in a bundle of wires. COme to find out the connector that is under the car under the rear passenger seat drivers side that feeds the fuel pump was croaded. took apart the connector cleaned it and re-tightened the connector pins, problem solved.
This was also after replacing the opti, it had gotten water in it and trashed it. So we had 2 issues bad opti and bad pump connection.
I replaced the opti today and it didn't fix it
, seems like I'm not getting spark out of the coil (Which I replaced already) ..any more comments will be greately appreciated..Adam
