Base pan....
Old Jul 6, 2009 | 07:44 PM
Justin Gibbons's Avatar
Default Base pan....
can i remove the base pan without removing the engine in my car.
Something let go while dyno tuning and want to get a quick look to see the damage....it's going to be weeks before I can pull the engine.
Old Jul 6, 2009 | 09:51 PM
anyone???
Old Jul 6, 2009 | 09:57 PM
elias_799's Avatar
you mean the oil pan ?
yes you can remove it with the engine still in car.
1 put a jack under the crank pulley
2 remove the 4 bolts on each motor mount connected to the k member
3 pump the jack slightly to lift the motor up
4 undo the 3 k member bolts on each side
5 let the k member hang down
6 remove all the oil pan bolts and the pan should come out no problem
let us know how it goes. good luck
