241 to 243 swap. What length pushrods?
Old Jul 8, 2009 | 10:32 AM
alamantia's Avatar
Default 241 to 243 swap. What length pushrods?
I have a 2002 Z28 with stock 241 heads and 7.400" pushrods. I have a set of 243 heads with the yellow sprongs I want to install. I have read conflicting posts about which length pushrods to use. Any advice?
Old Jul 8, 2009 | 10:41 AM
EDS01SS's Avatar
If everything else is still stock then I dont see a reason why you would need anything other then the 7.400 pushrods
Damian's Avatar
LSX Mechanic
If the deck is unmilled on the 243's, a 7.4 should be fine assuming you're using an LS1 lifter.
Old Jul 8, 2009 | 07:50 PM
97ta383's Avatar
Im about to do the same thing and i have asked a few people includeing an owner of a f body shop and they all said stock pushrods will be fine.
