Tr6 for cam only?
Old Jul 8, 2009 | 07:25 PM
therobman's Avatar
Default Tr6 for cam only?
well i have a set of these laying around from when i baught msd wires they came together my question is can i use tr6 plugs in a cam only car i might spray at some point but its not likely
Old Jul 8, 2009 | 07:29 PM
b00sted's Avatar
That's what I'm using. It won't hurt anything.
Old Jul 8, 2009 | 07:43 PM
01ssreda4's Avatar
prolly wont hurt but most agree that tr-55 for non-spraying cars.
Old Jul 8, 2009 | 07:44 PM
vettenuts's Avatar
NGK recommends you drop one heat range for every 100 hp increase so they should be fine. Better to error on the cool side then the hot.
Old Jul 8, 2009 | 07:51 PM
DONAIMIAN's Avatar
I was about to say the same thing.
Me personally, I ran the 55's when I was cam only. With the added compression of the new set-up I'm running the 6's.
Old Jul 8, 2009 | 08:11 PM
therobman's Avatar
thanks guys just wanted to make sure it was fine should be a step up from the a/c delcos lol
Old Jul 8, 2009 | 08:42 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I ran the TR6s in my old '02 Z28 that was cam only and never had an issue. Then I got a TNT kit and sprayed the **** out of it
