Motor find.
Old Jul 8, 2009 | 09:57 PM
LILWS6's Avatar
Default Motor find.
I'm not really shure where to put this and its been awhile since i've been on here. So real quick i've always wanted to build a motor slowly out side of my car so i could just swap it in. Well at work i scored a 02 i think suburban 5.3 liter motor minus heads. Is it worth building this motor for my trans am or should i continue to look for something better? will the motor even bolt in? thanks guys/gals
Old Jul 9, 2009 | 09:10 PM
LILWS6's Avatar
any one?
Old Jul 9, 2009 | 09:15 PM
KCS's Avatar
KCS
Moderator
I wouldn't bother, but that's just me. You could make it into a 347ci iron block on a budget, but I would rather spend the extra money on a 6.0L block and gain nearly 30ci.
However, it should be able to swap in, but I think you would need to drill and tap a hole on the front of the block, driver's side, for the power steering.
Old Jul 9, 2009 | 11:15 PM
OMGWTFBODY's Avatar
5.3s make a good budget motor, but the stock LS1 has more potential.
Old Jul 10, 2009 | 08:19 PM
LILWS6's Avatar
so i'm pretty much looking at selling it? would it be worth it to build it to handle a turbo or super charger rather then try and stroke it because. idealy i wanted a 408 stroker. if i can't do that is it worth going the turbo route?
Old Jul 10, 2009 | 08:28 PM
406malibu's Avatar
If you plan on going turbo route, thats a great budget motor. There's a couple guys in the forced induction section with turbo 5.3's pumping out 700+ on pump gas with meth.
