Will an 05 LS2 GTO cam work in a LS1???
Old Jul 16, 2009 | 10:07 AM
MBC Racing's Avatar
Default Will an 05 LS2 GTO cam work in a LS1???
I am rebuilding a high mile LS1 and was going to put my stock 06 GTO cam in as a minor upgrade..... Found out it won't work since there is no pickup on the cam for the cam sensor.... Guess that part is a paper weight now...
Will the 05 LS2 cam work or is it basically NONE of the LS2 cams work in a Ls1???
Thanks!!!
Old Jul 16, 2009 | 10:51 PM
blackLS1m6's Avatar
the 05 ls2 cam will work because it is a 2x reluctor like the ls1, the 06 and up ls2's are 4x
Old Jul 17, 2009 | 08:32 AM
MBC Racing's Avatar
I was able to answer my own question.....with the help of Speed Inc. LS2 cams will not work in ls1 engines UNLESS you use a LS2 front cover and the cam sensor extension harness. You also need the LS2 2x timing gear for the cam since this is what the sensor looks at. I will be picking up the parts from them today so the motor will be back together tonight.
