853's vs 317's
My question is can I run the 317's on my new motor with no PTVC issues while running the MS4 that's in the new block already? I don't think they have been milled or anything. I understand that I will have to check PTVC, but are 317's basically the same? Also, will I have to run bigger (6.0) head gaskets?
I rather just swap the springs from the heads with the bad valve and run the 317's on my LS1, if this is possibe. Also, will the springs be interchangable from 853's to 317's?
Let me know what you think.
Also, can anyone confirm what head gaskets I would need to sue with the 317's?
Thanks guys!!
