How much hp can i get??
Headers: Qtp, Kooks, Mac Mid Lengths
Y-pipe: I would run cat less if you dont have emmisons. If you have emissions I would run a cut out off of a catted Y pipe and that will solve the emissions issue, while still providing at the track with good performance.
Camshaft: Here is were it gets tricky, max hp people love big cams. Big cams arent always the most streetable cam. So, I would call around and talk with different camshaft companies. Texas Speed, Thunder Racing, Comp Cams, Etc.
Heads: you have a 2001 so you have the 241 heads which is a good stock head. And, since you didnt mention heads I wont worry about them.
Intake: Since you are a 2001 you will have the LS6 intake which is a good intake IMO. I would upgrade to the FAST 92/92 Combo.
Injectors:You should be fine with stock injectors, if you were going to upgrade I would do 42lb injectors till you figure out what direction you want to go with your motor.
Tuning:THE MOST IMPORTANT thing out of all. Make sure you can find a good tuner that will explain to you what he is doing and will work with you on helping you upgrade your car correctly and safe.
MAX Horse Power: JUST ADD NITROUS!!! HSW Sudden Impact Kit is 422 Shipped and will give you up to 150 shot jets. That would be my first mod if I was you and wanted MAX HP!!!
I agree except headers, if no emissions just go long tubes and a x pipe I would go with Texas speed headers they are very good headers and cheap and they have a x pipe that will fit just bolt on no customizing but besides that i think it looks good
- FAST 92 with 95mm TB
- Stage 2 LS6 heads
- 224/228 Comp Cam
- 42 lb Ford Motorsport injectors
I'm looking for 425 + RWHP out of it. But you need the bolt-ons first! Bottom 11's should be there
As for injectors, I'd go with 36lb or 42lb, those should hold fine, and the 42lbs will give you some leeway for future mods or even nitrous.
Don't buy the MSD coils or ignition, kind of wasting money there, as the stock units are very good, but some MSD wires won't hurt as well as some NGK TR55 plugs.
A good tune is VERY necessary.
Your stock clutch won't hold that power for long so yes I would be looking into another clutch. Some like the LS7 clutches, but they're heavy. Monster, RAM, and SPEC are some possibilites, and a lightweight flywheel will free up some hp as well.
As for ring & pinion and the alum DS, the stockers will be fine as well. Hope this helps.
You can net big power for less money than building and swapping an LS2, so just figure out what would suit you the best, and pick a nice matched combo. You don't always have to go with the biggest cam and the highest flowing heads. A properly setup combo will outperform some of the "donkey dick" cam combos.
thanx 4 ur comment bro,the problem is im confused whatever to buy ls2 or ls3 engine or just modify the same ls1 engine cauz we all know that ls1 block has its limition maybe it will break/crack after 800hp?!!
Once i had SPEC clutch but the fools in the garage didnt install it correctly then it eaten out!! so I replaced it with stock clutch
I'll try to go with 42lb for future mods
Thanx agian
Also to the Original Poster, check out the stickies and threads on here like tatasta said. I have spend alot of time on here just browsing aroung the forum, learned all about the motor, chassis, etc.. You can build alot of power with these cars but you will need to replace the entire drivetrain if you are going to break the 450-500+whp barrier in my opinion for sure. Especially with a 6speed, the rear end doesn't last, so on and so forth. Keep your options open for the vehicle. Put some consideration into what you want to do though, take your time. Good luck bro
As u said the rear end should be changed if I want to exceed 500whp
A proven H/C combo from any sponsor here will give you a nice SOTP upgrade over your sotkc LS1. And boltons are the first thing to do by the way. If you go y pipe, go catless and cutout, its good for +-10rwhp with H/C.
By the way, buy some nice heads wayyyy before FAST intake(same price and better gains!). FAST should be the last bolt on IMO.
..and read the stickies!!
For the right cam, you really have to read a long time. some plp are all about small street cam with nice powerband like 224-228 cams, while some plp are go big or go home style..I can say that my little TR224 cam is doing a nice job, but I cant wait to go bigger, like 234-238 cam
Its all about your needs, driving style and car purpose(track/street/DD/weekend warrior..) plus the gear you chose will affect the cam manners. And you must have a good tune
Im really sorry to tell u late that my engine its replaced before i purchase it,now it has 1997 ls1 engine,i think its written 853 on heads,so it dont have ls6 intake and the there's no emission wire from the intake?!! maybe the guy i buy the car from has take it out!
I think now the mods which I've to put will be between 1997-1998 ls1 parts right?? If u need engine pics just tell me
why x-pipe?
- Stage 2 LS6 heads
- 224/228 Comp Cam
this the real matter,if the block can handle max hp so i dont need 2 replace it
so ur saying that H/C should go along with good intake right??
So if strokerd with bolt-on it give nice and max numbers? I thinking to start with bplt-ons at the moment
