Please check these cam specs for me !!
Valve Lift: .559 / .559
Duration: 226 / 274
Duration @ .050: 214 / 220
Lobe separation 115
Intake centerline 111
I was going to buy this as a sleeper cam . For 175 $ seems like a good deal . Is it 4* retarded and if so what does that mean as far as the powerband goes ?? Will I need an adjustable timing chain etc ?? How can you tell ??
Thanks guys
thats a pretty mild cam and im sure you can get better hp out of a mti stealth cam or another stealth grind.
and you wont need an adjustible timing chain unless you want one or want to adjust the timing. i wouldnt. it already has some ground in. i'd install it straight up. dont forget new springs also.
212 218 558 563 115 lsa
and this cam seemed very similar . I was going to run it with the magnum 1.75 's for a bit more lift but If it sucks Ill save my pennies for something else
I am running a 229/233 on a 114, and it barely lopes UNtuned FWIW...
josh
i agree with damian about going bigger, i'd of said the 224 on the 114, the 220 114 would be more of a stealth cam. but any cam with the proper tune should be able to sound almost stock
Its not even the stealthy sound im after , I dont mind the lopey sound its the rocking and sputtering / shuttering at the lights and when idleing that drives me nutty . I want the smooth idle without a quarter size hole drilled in my tb
I think the new "stealth" cam is pretty close to TR's 220 cam. The cam I am talking about is a Thunder 220/220 .568/.568 114+4. This cam will make GREAT HP and TQ throughout the entire rpm range. Peak will be roughly 6200-6300, and will drive and sound just like a stock car with a tune. This I can promise. I put this cam in a buddy's car when TR first offered it, and he hasn't changed since. It's a great cam. Made 413 rwhp on 3 yr old heads in his car and you wouldn't even know it's there.
The TR224 on a 114 would even be a good choice if you aren't scared of a LITTLE lope. Even that cam sounds almost stock and will make ~8-10 over the TR220. Both are great cams, easy on springs, won't surge, and make great power with stock or ported heads. I would recommend getting either cam on a 114+4. This puts you on a 110 ICL, and will help low end TQ. When you start retarding cams, you lose low end and bring your power band up higher.
IMO, go with at least one of the two listed above if you're going to go through the trouble and spend the money on a cam swap. I have seen plenty of these cams in action, and I wouldn't even waste my time on something smaller than a TR220.
josh
dude, the 224 114 is perfect, with a tune its smooth as a babies ***
. it'll give you great power. just do a search and you'll see, its one of the best mid range streetable cams out there. 224/224 .563/.563 114. will run on stock tune but tunning is best to just smooth everything out. my 230 with a 110.5lsa untuned lopes like a muthafucka but its nothing that shakes the whole car around to where its annoying or anything
. i had to drill a 13/64 hole to get mine to idle. I think you'll be the happiest going that route. Forget about all the other wastes of time you mentioned
Josh
Go directly to Geoff @ thunder. Give him a call and he'll talk your head off and give you all the information you'd ever need
Good luck,
Josh
Next thing you'll have me talked into a g5x2
for real though, i think the 224 will be your best bet. and if you dont like one you can sell it to me cuz im gonna down grade to a 224 myself, but on a 112
. I'd go with a 220 to 224 sized one on a 113 to 115 LSA with fast ramps. The TR cams are good starting points.
What would be an estimate of power increase with the TR224 cam on stock heads? any dyno sheets? Im looking into a TR224 cam myself.
Right now I have an airlid, 160 stat, 160 fan settings, corsa exhaust and y-pipe and I dynoed at about 325rwhp.
1) Would I be able to see 400rwhp with a set of LT 1 3/4" headers, 3" Catted Y pipe and safe tuning with stock heads (not ported)?
2) What would I expect as far as quarter mile times and most important trap speeds with the full 3" exhaust setup?
hope these questions would help joe dirt to decide as well.
on stock heads with full bolt ons 400rwhp is possible with the tr224 on stock heads. more likely you'll hit 380-390 but thats still very respectible on stock heads.
