how to run an ls7 dry sump on a 427 MID darton ls1
anyone know how to run the ls7 oil pump with the longer snout and still be able to use fbody accessories?
i got a real good deal on a take off ls7 dry sump system with tank and lines. i just need to figure out the accessory drives issue. what pulley will line up to my fbody stuff. any info appreciated.
I'm about to throw a dry sump ls6 into an f-body and I'm wanting to find out if I should adapt the car to be a dry sump and how or If I can use an ls style oil pump and about the pulleys also. Anybody??
