6.0 liter heads
Old Feb 17, 2003 | 01:05 PM
Redline-Motorsports's Avatar
Default Re: 6.0 liter heads
Yes the later heads are aluminum. They are typically a 70-71 cc combustion chamber and the intake and exhaust ports are identical to the LS6. I would suspect they would drop compression by a good .5-.-6.
They are great for a superchargered or NOS motor where you can use the head flow and lower compression.
Old Feb 17, 2003 | 02:04 PM
smokinHawk's Avatar
They flow great 210cc intake 75cc exhaust same as ls6. Resoponds well to porting also.
I got them and think their worth it.
gm high perforance this month has an article about the ls heads.
Old Feb 17, 2003 | 04:05 PM
70 LS1's Avatar
Conversion master
What size valves did these come with? what about the springs?
Old Feb 17, 2003 | 05:57 PM
LS1derfull's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by smokinHawk:
<strong> They flow great 210cc intake 75cc exhaust same as ls6. Resoponds well to porting also.
gm high perforance this month has an article about the ls heads. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I measured lS6 intake port stock and it was 215cc. Some on here claim there is differences in port design also between 6.0 and LS6. I have yet to mess with 6.0 heads, so i cant back that.
Old Feb 18, 2003 | 12:43 AM
70 LS1's Avatar
Conversion master
Default 6.0 liter heads
How well do the 6.0 liter heads flow? How much do they drop compression? Are they aluminum or cast iron? Is there anything else I should know about them?
thanks
