Thin head gasket 243 head swap
Old Jul 23, 2009 | 09:27 PM
mtuggle86's Avatar
Default Thin head gasket 243 head swap
hey guys im putting a set of ls2 heads on my stock bottom end ls1 and I want to bump the compression a tad bit more by going with some thinner head gaskets but the .040 cometics are like 160 bucks are there any other brands that have a gasket that will bump my compression up but are a bit cheaper?
Old Jul 24, 2009 | 01:50 AM
00MaroonZ28's Avatar
Screw the cometics. Too many problems with blown head gaskets with those. Just stick with the GM gaskets.
Old Jul 24, 2009 | 06:47 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
The key to getting any gasket to work well is surface prep. If it's not perfect, keep working on the surface to get it perfect to make sure you have a suitable surface to seal.
As for cheaper gaskets, try Felpro. I think they are ~$45 each.
Old Jul 24, 2009 | 08:54 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
I think this is a great move. I've had really good luck with a properly installed set of Cometics. I'm going to do some testing on this at some point so I can get you a idea of power gains just from the gaskets.
If you need a set give us a call, we stock every thickness & bore you could imagine!!
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jul 27, 2009 | 03:58 PM
FBODYFEVA's Avatar
Anyone know the gm part number for the gaskets??? Or is there a difference with stock ls1 gaskets
Old Jul 27, 2009 | 06:24 PM
UNDER PRESSURE MOD
I'd love to see the difference in going from a factory mls gasket of 0.056" to a cometic 0.040".
