Calculating valve overlap?
Old Jul 30, 2009 | 10:48 AM
SS#1230's Avatar
Default Calculating valve overlap?
okay ive been researching this but cant really find a definate answer.
ive got all the specs i need on the cam card.
okay, lots of guys talk about a cams overlap using durations at .050, instead of the cam duration at initial opening and closing points. ive read that you need to have that info do accurately figure overlap.
lemme know what your guys formulas are...
my cam duration at .006" is 271/280 on a 112lsa ( lobe center lines are 109int and 115exh)
thanks,
Jeremy
Old Jul 30, 2009 | 11:07 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Overlap at .006" is calculated the same as at .050" and .200"....just use the durations and LSA at that lift.
(Intake Duration + Exhaust Duration)/2 - (LSA*2)
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jul 30, 2009 | 06:51 PM
HSVGTS300's Avatar
So Matt,
My 228R on a 112 LSA has 4* overlap @ .050 and 53* @ .006.
When talking overlap of a cam i assume its the 53* that would be mentioned?
Cheers Mike.
Old Jul 31, 2009 | 09:29 AM
Originally Posted by HSVGTS300
So Matt,
Cheers Mike.
Correct. 4º@.050", 53º@.006", and -75º@.200" in case you're interested.
More often than not, when people refer to overlap on the forums they are speaking of the .050" numbers.
__________________
Old Jul 31, 2009 | 12:29 PM
PREDATOR-Z's Avatar
Or if you have a cam card
IVO+EVC= Overlap
