Head gasket!
Old Jul 30, 2009 | 12:21 PM
captainstalin`'s Avatar
Default Head gasket!
ok so im buying head gaskets
the bore is 3.910
do i go with 3.910 bore gasket or 3.950?
tell me why.
Old Jul 30, 2009 | 01:21 PM
L33_944's Avatar
The 3.950 would be if it were bored out. Maybe someone can second that
Old Jul 30, 2009 | 04:17 PM
Lazpno's Avatar
Call the gasket company and ask them. Easiest and probably fastest way to get your answer. FWIW I'm running a 3.909 bore and run a 3.940 gasket, as directed by Cometic.
Old Jul 31, 2009 | 10:27 AM
i was looking into ssc copper gasket but they only have the 3.950 i suppose gasket companies prefer that you go .04 over?
Old Aug 1, 2009 | 06:20 PM
Lazpno's Avatar
There is no need to "suppose" or assume. Just call them and ask them. If a gasket company can't tell you what gasket to run for what bore on your block then you probably shouldn't buy gaskets from them.
