anyone try these valve covers?
Old Aug 9, 2009 | 09:38 PM
crashinaz's Avatar
Here ya go. Welds are good. Hardware is all there and good. The main difference I see between these are the $400+ covers is the gasket rail. Others are billet and these appear to be punched out and machined instead. I checked the flatness with a machinist straight edge and they're perfectly flat. I don't have coil brackets yet, so no coils installed pics.
http://photobucket.com/FabbedAluminumValveCovers
Old Aug 9, 2009 | 11:08 PM
GA95DCMSS's Avatar
Cool. They definitely look good enough. My only worry would be about the sealing of the gasket rail after repeated torquing, seeing as they are machined vs. billet.
I'd get em polished up, and PC'd Clear, except on the gasket rail to prevent oxidation.
Old Aug 10, 2009 | 11:45 AM
crashinaz's Avatar
Eh... You can over engineer anything. It's a valve cover. Is billet nicer? Yep. Necessary? Nah...
Old Aug 10, 2009 | 11:55 AM
transaman98's Avatar
ooh! real nice! I think I am gonna pick a set of these guys up then! Does anyone know what the LS6 valley cover cost? Since I have a 98 would I need to get a set of coil brackets?
Old Aug 10, 2009 | 12:03 PM
crashinaz's Avatar
Yep...
Old Aug 10, 2009 | 01:05 PM
02SLOMARO's Avatar
i can get these at my store. the satins are $150 shipped. the polished are $170 shipped. both styles come with a clear coat on them so you wouldnt want to use an abrasive cleaner. good old glass cleaner does the trick.
Old Aug 10, 2009 | 01:14 PM
Spd-Kilz's Avatar
You're looking at about $80 from Scoggin Dickey, for the LS6 Valley Cover.
You will also need the brackets, unless you choose to relocate the coil packs. LS1 brackets are ~$30 from SDPC.
Old Aug 10, 2009 | 01:23 PM
02SLOMARO's Avatar
if anyone wants a set or is interested feel free to call.
grand prix auto sports center
4915 e. admiral pl
tulsa, ok 74115
1(800)331-2223
ask for chris
Old Aug 10, 2009 | 01:41 PM
bluehawk2's Avatar
will these covers clear aftermarket rockers hs yella terra etc.
Old Aug 10, 2009 | 01:50 PM
crashinaz's Avatar
T&D Machine shaft mounts under mine.
Old Aug 10, 2009 | 02:03 PM
bluehawk2's Avatar
i'm gonna give these a try...........they look really good
Old Aug 10, 2009 | 02:05 PM
  #32
bluehawk2's Avatar
will I need longer spark plug wires with these? I have msd's right now
Old Aug 10, 2009 | 02:13 PM
  #33
ooh good question. I never thought to ask that but the pedestals for the brackets/coils to mount on look a bit taller don't they?
Old Aug 10, 2009 | 03:05 PM
  #34
02SLOMARO's Avatar
being that they an 1 1/2" taller i believe you will have to run longer wires, also they should clear most if not all aftermarket rockers.
  #35
02SLOMARO's Avatar
thanks for the order bluehawk2!
Old Aug 10, 2009 | 06:10 PM
  #36
crashinaz's Avatar
You should probably contact one of the Mod's before you sell anything else.
Old Aug 10, 2009 | 07:34 PM
  #37
yeah lets try not to get this thread locked... Where would I go to order new plug wires that are longer? Do they have to be custom ordered or does someone on here sell them at the correct length already?
Old Aug 11, 2009 | 08:54 AM
  #38
02SLOMARO's Avatar
who is a mod and what do i need to do? bluehawk suggested the ls series truck engine wires. they are a little longer.
Old Aug 19, 2009 | 11:57 AM
  #39
02SLOMARO's Avatar
i am only posting this because i cant post in the for sale section. the good old 50post/6mnth rule. but here are some pics of a set i got in.
Attached Thumbnails anyone try these valve covers?-ls1-valve-covers-001.jpg   anyone try these valve covers?-ls1-valve-covers-003.jpg   anyone try these valve covers?-ls1-valve-covers-005.jpg   anyone try these valve covers?-ls1-valve-covers-006.jpg   anyone try these valve covers?-ls1-valve-covers-007.jpg
Old Aug 19, 2009 | 02:43 PM
  #40
NemeSS's Avatar
what kind of gasket do the use?
are they available without the coil mount columns?
as in completely flat.
come with bolts?
