Help me find some missing horsepower
I know going with Longtubes will net me more power but I still expected at least 370 through my mac mids. Does anybody know how the Hooker aerochamber muffler flows or if it could be the stock MAF or LS1 throttle body? The numbers seemed to stop climbing too early.
I want to find the missing hp so I could reach my new goal of 400rwhp with the LS6 heads, .040 gasket, and 3200 stall. (410rwhp if I didn't get the stall) Thanks.
If you really want 370rwhp from your setup, you probably need to address a few things:
1) replace MAC mids with better quality long-tube headers (Kooks, QTP, American Racing)
2) build another merge style Y pipe with out cats
3) home port your throttle body for what it's worth
4) if you didn't at install, degree the cam and see that it is setup properly
5) if you have aftermarket Y2K wheels, they can be heavier than stock and skew your numbers downward. Try refitting the stock 16x8's if you still have them.
If all else fails, your plans to add LS6 heads and thinner gaskets will help out that cam quite a bit. Evne if you end up at 395rwph after all of your efforts, that should be a hard running, well rounded setup that works well.
Best of luck with your build!
I was thinking about cutting off the shitty connectors on the headers and y-pipe and putting straight pipe since I saw someone do this on here and gain 5rwhp.
http://photos.streetfire.net/photo/1539236.htm
here is a picture of the headers with the carsound cats welded in before they were installed.
The first time I went to go dyno my car before the pulley,tune, headers,cam it only managed 289rwhp on a dynojet since it hit a limiter at 4600rpm. It was on it's way to about 315rwhp though.
