Valve spring question
Old Aug 10, 2009 | 09:39 PM
c130nav's Avatar
Default Valve spring question
This has got me kinda baffled: In the middle of a cam swap; installed a Ling GT2-3 cam in our LS1. A local speed shop checked a set of what are supposed to be LS6/Z06 springs. They are stock looking silver springs (not yellow), and the guy put them on a spring compressor and said they are good for up to .593 lift and still have .050 gap between a couple of coils when compressed. This cam has a lift in the .570-.580 range. I swapped the springs on the #1 cylinder and installed pushrods and rockers and ran the cylinder through a full cycle. At full valve lift on both intake and exhaust, I can put a .060 wire between a couple of coils at full valve lift. These springs looked exactly like the stock silver(brownish oil colored) already installed in all the other cylinders. So for shiites and grins, I checked the #3 cylinder with the original installed springs, and I got the same gap in the coils at full valve lift.
Question: Do I have to change out the springs already installed in the motor based on what I measured when turning the cylinders by hand. Or, will oil pressure cause coil bind when the lifters pump up?
Old Aug 10, 2009 | 09:47 PM
02*C5's Avatar
It depends on the age of the springs and what they have gone through. Regardless for "Shts&Ggls" it can be the difference between a few hundred dollars or a few thousands. Its up to you advice is free. Me every H/C package unless I have had the springs and know how old they are and what they have been through I change them.
