How safe am i???please help...
Old Aug 11, 2009 | 01:58 PM
LS1Xtreme02's Avatar
Default How safe am i???please help...
I need to know how safe it is too run an x1 cam in a motor with 100,000 miles...do i have to worry about the cam bearings???thanx in advance...
Old Aug 11, 2009 | 03:31 PM
Damian's Avatar
LSX Mechanic
It's 100% safe. Lots of topics posted on this, and lots of 100K+ setups out there.
Just change your oil pump & timing chain while you're in there, and it'll be good to go.
Old Aug 12, 2009 | 05:34 PM
Yeah ill be doing that as well...thanx...
Old Aug 12, 2009 | 05:38 PM
lemons12's Avatar
i ran an ms4 cam from 100k miles-116k miles.. no troubles at all!
hardened push rods
dual springs
ls6 oil pump
ls2 timing chain
Old Aug 12, 2009 | 11:17 PM
Good to know...ill be doing all the following mentioned above except ill be using 918 springs...thanx again guys...
Old Aug 12, 2009 | 11:20 PM
lemons12's Avatar
you should be fine.. what is the lift on that cam?
