Leakdown Results :(
Old Aug 12, 2009 | 08:53 PM
ablakez28's Avatar
Default Leakdown Results :(
Ok so a friend of mine did an LS1 swap into a 240sx. While the motor was out the following was done:
MLS Headgasket
LS7 lifters
Dual springs
Hardened pushrods.
Leakdown comes in at
1-10
2-11
3-22
4-0
5-0
6-11
7-19
8-19
He said that even with the rockers tq# 22lbs he can move them if that makes sense. Well any help would be appreciated. I am think possibly PtV contact? Valeseals? Pushrod length?
Thanks,
Andrew
Old Aug 13, 2009 | 01:29 AM
2001ws6-500hp's Avatar
the rockers should be loose when the valve is completely shut. the rocker mount is seperate from the rocker arm. take all of the rockers loose and do a leakdown test. that will rule out pushrods and rocker problems. then it only leaves it to rings, gaskets, ptv problems ect. list what cam u have and what heads,
Old Aug 13, 2009 | 02:58 AM
ablakez28's Avatar
Sorry I can not believe I forgot to add that info! I was running out the door anyhow it is this cam
http://www.neweraperformanceparts.co...V=fthelcamfb|0
Stock heads with MLS gaskets.
After checking it out I worry he has piston to valve issues.
Old Aug 13, 2009 | 07:14 PM
ablakez28's Avatar
TTT lets hear it. PtV issues is my best thought.
Old Aug 13, 2009 | 07:43 PM
crainholio's Avatar
With the leakdown gauge attached and pressurized, whip out your mechanic's stethoscope and listen for the source of the leak.
Intake valve = hiss audible at the TB
Exhaust valve = hiss audible at the exhaust manifold
Rings = hiss audible at the dipstick
Old Aug 13, 2009 | 09:26 PM
eallanboggs's Avatar
Gasket: air bubbles in coolant tank. Removing the rockers is a good idea since it doesn't take a lot of work to put them back on. Make sure piston is a TDC. It doesn't matter what stroke your in in this situation since you've got the rockers and pushrods removed.
Old Aug 13, 2009 | 09:51 PM
Sharpe's Avatar
Old Aug 15, 2009 | 05:23 AM
my moneys on valves.
