cammed CTS-V , LS6 :)
Old Aug 14, 2009 | 06:00 PM
maxspeed96ct's Avatar
Default cammed CTS-V , LS6 :)
I finally finished my cam install.
after much searching I went with this cam
http://www.summitracing.com/parts.as...=CCA-54-416-11
220 int./224 exh 112 lobe 0.530 int./0.534 exh. lift
Reason I chose this mild cam is the CTS-V is kindof my Daily driver. I still want good drivability and respectable gas milage.
Some say you could use the stock valve springs some say you cant, I ended up going with a patriot gold dual spring kit with titanium retainers just to be safe. But im sure LS6 springs would of worked to.
Also got the hardend push rods, new plugs and 8.5 MSD wires.
The cam install wasnt to bad, the A.C. was a pain to work around, I had it in the air hanging from the hood latch.. but other then that wasnt bad. Also the timing dots are harder to see compared to the LS1, not sure if every ls6 is like this or just the V. It has a extra gaurd around the crank area.
But the valve springs really got the best of me, there isnt much room to work in . And the tool I have sucks, ended up welding a socket on it which helped but it still sucked....I recomend if you plan on doing this buy one of the fancy tools that bolt down and can do 2 springs at once. it will save you lots of headache. Also I had some trouble attaching the leak down kit into the spark plug hole.
Car sounds awsome, I still have the stock headers , with a x-pipe and my mufflers are quiet , which is nice cause it stil lsounds good, but has a nice rumble to it.
Going to dyno sometime next week and tune in the near future, next summer ill toss on some headers.
Big thanks to the guy that made this write up,
http://ls1howto.com/index.php?article=23
and SS#1230 for answering a bunch of questions.
and other that replied my threads and etc..
here is a video and some pics.
Turn your volume up for the vid, my camera isnt that great and also my mufflers are quiet. plus im on stock headers.
http://www.youtube.com/watch?v=OInu0aW6GQI
Old Aug 14, 2009 | 09:25 PM
VincesSS's Avatar
Congrats on the install! You can barely even hear it.
Old Aug 14, 2009 | 10:13 PM
jlrz28's Avatar
10 Second Fun Car
Sounds good....it will be interesting to see the numbers with the manifolds.
Old Aug 15, 2009 | 12:07 AM
David_viny's Avatar
Nice! Definitely cant wait to see the dyno numbers, I'm looking to possibly do a somewhat similar setup with my TA. A small low lift cam with LS6 heads and stock manifolds/cats. Do you have all the stock cats on the exhaust?
Old Aug 15, 2009 | 03:31 AM
Johnnystock's Avatar
Congrats on the nice install!
...I would at least LTs and tune on your V!!!
Old Aug 16, 2009 | 12:02 AM
going to tune very soon, but no long tubes till maybe next summer. still on stock headers and cats right now.
I got my hands on a better camera, heres a much better sound clip.
http://www.youtube.com/watch?v=xvvYomyxHOA
what do you guys think the ls6 will dyno on stock headers, ~370 maybe more ?
