mahle piston ring/engine build help
Old Aug 15, 2009 | 01:12 AM
Gregorya24's Avatar
Default mahle piston ring/engine build help
while we were putting together my shortbock tonight we started on the first piston compressing the rings, one of the oil scrape rings got caught just a little bit to bend it enough. We straightened it out but i dont feel comfortable enough putting it in.
The 7 other pistons went in perfect and seated/felt good.
Does anyone know if i can just one oil scrape ring from mahle for a 3.908 bore piston? or any reps on here?
Old Aug 15, 2009 | 11:26 AM
Gregorya24's Avatar
nobody knows where i can order one oil scrape ring for a 3.908 bore mahle piston?
Old Aug 16, 2009 | 01:16 PM
JPH's Avatar
JPH
Call MAHLE MOTORSPORTS man and they can send you one! #1-888-255-1942(ask for tech) and reference ring package #3910ML-043 I believe. Good luck.
