Stick with the 346 or jump to the 408?
Now, I'm considering going with a 408. I've already got the block/crank like I said earlier for the 346 so it would be easier I suppose. My biggest issue with the 408 is the weight of the iron block. I switched to aftermarket K-member/A-arms. Deleted the abs, and stripped the AC out in an effort to save weight. I picked up Strano sways, springs and Koni's because I want the car to handle well and I don't know how the extra 80lbs or whatever it is in the front is going to affect the handling...
I have been seeing very decent numbers out of the 408's, which I do like. The 347 would put out respectable numbers I guess, but not have the potential and torque that the larger motor would.
I'm kind of at a crossroads here.
What would you guys do given the same decision? Will the extra weight of the iron block greatly effect handling? How much will the LS1 block/crank be worth? It's in perfect shape and was pulled out of a 17K mile Camaro.
Thanks guys,
Drew
A 402 will run about $800 more by the time you figure in TC cover, LS2 valley cover, harness extensions etc...... In short a 383 can meet my goals and not break my wallet but if it is in your budget a 402 is SWEEEET....
Plus with the 408 it's an easy swap with no adaptors of changes needed.
