Aftermarket rockers?
I'm looking at stage II heads and a cam something like 228/228 112lsa with under 0.600" lift. I love the look of the Comp Cams shaft rocker system and there's no doubt they won't flex, but $840 is 50% of my 12 bolt rear end budget!!! Where does it end? Do I need to replace the stock rockers or can I feel comfortable bolting them back into my new heads?
I've heard poeple say that anything under 0.570" lift OEM is fine, but the little devil on my other shoulder can't help to point out that after changing the cam, springs, retainers, pushrods and bushings...the rockers are the weak link remaining in the valve train
I will have a shaft mounted rocker system available real soon.These will be fully adjustable 1.7 ratio.The cost will be $549.00 .
Let me know when you have this available
. There pretty precision looking little suckers , a far cry from my old 5.0 stamped steel pos's . I think Im going to keep them in there for a while
