Heating issues
Old Aug 17, 2009 | 03:12 PM
02*C5's Avatar
Exclamation Heating issues
Ok so the new H/C is done. I live in Az so I am having issues with getting hot while standing in traffic or city traffic (240-250) so am debating weather get a 3200+ cfm fan, and stay with the stock radiator or should I go with a cross flow radiator with stock fans. I am also thinking of changing my mix of coolant to 1 1/2 gallons of distilled water, 1/2 gallon of coolant, and 2 bottles of purple ice.
What say You
Old Aug 17, 2009 | 04:13 PM
TooLateVTEC's Avatar
Did the heads change the compression at all or did it just all of a sudden start overheating? Are you positive that all the air is out of the system?
Is there an air dam under the front like there is on f-bodies that you forgot to put back on?
Ive never used purple ice, but ive used water wetter in the race car before and it made almost no difference when it was hot and humid here.
Also make sure there isnt some piece of trash that got sucked up into the radiator and maybe try hosing it out before you try to change fans and ****.
Old Aug 17, 2009 | 04:22 PM
joecar's Avatar
+1 for getting air out...
is radiator cap good (does cap hold rated pressure)...?
Old Aug 17, 2009 | 04:24 PM
ls1freak33's Avatar
What say You
theres a chance of ur the thermastat is bad too
Old Aug 17, 2009 | 06:49 PM
02*C5's Avatar
ok Ill drain her re fill her and see what happens.
the radiator was blown out before remounting
the thermostat is new, but it could be bad
the cap was pressure tested by my buddy and he said it was good
The deck was only milled very lightly no big difference in compression ratio if anything from 10.5 to 10.8
Ill be back as soon as I get her out again.
Old Aug 17, 2009 | 07:16 PM
crainholio's Avatar
What temp are your fans programmed to come on at? Stock settings, or tuned lower?
Which thermostat are you running?
Old Aug 17, 2009 | 07:19 PM
02*C5's Avatar
Stock setting because I was told that its a big drain on the altenator and I could fry it with time if I started them any sooner, and I am running a 160 thermostat.
Old Aug 17, 2009 | 08:26 PM
crainholio's Avatar
Fans draw the same current regardless of what temp they come on, they're just electric motors.
Did the guy really tell you that fans draw more current when they come on at engine temp 230 versus 200?
Go nut-kick whoever told you that fib. And then set your fans lower. I'd think about:
Fan 1: on 190, off 180
Fan 2: on 205, off 195
This assumes you don't want both fans running concurrently unless things are really hot.
Old Aug 17, 2009 | 08:53 PM
02*C5's Avatar
Oh man i needed to laugh and you accomplished that. I have had nothing but nightmares with my car LOL. OK I let me burp her and have my guy reset my fans and I will get back to every one. Thanks for all the advice. I was about to spend lobs of money to keep her cool.
Old Aug 18, 2009 | 07:57 AM
crainholio's Avatar
Glad to help!
Like you said, burp the air out of the system, get the fan temps dialed in, and go from there.
Old Aug 18, 2009 | 10:19 AM
01ssreda4's Avatar
Yeah I would look at the simple things first as already mentioned here. If need be though I would upgrade something, you dont wanna see 250 temps. I will say though my car stock in hot/humid weather would see 230-240 with AC running and it drove perfect. I had my fans adjusted and now it stays 190-210
