ls2 and 24x reluctor wheel Question
Old Aug 18, 2009 | 06:13 PM
TJ's Avatar
TJ
Default ls2 and 24x reluctor wheel Question
using a 24x reluctor wheel and an ls2 block. ive read and know i need a 2x 3 bolt ls2 style cam gear so it mates with the ls1.
is there ANY AT ALL modifications needed to the PCM to do such a swap?
reason i ask is im using a msd 6010 box for this setup, and it has NO programming whatsoever.
if extending the cam sensor wires and buying the proper pieces is all it takes then im good to go.
just want to make sure there is no PCM tuning needed to recognize the ls2 cam sensor with the ls1 wheel.
Old Aug 19, 2009 | 03:15 PM
SIC LSX's Avatar
anyone???
Old Aug 19, 2009 | 05:52 PM
Jon@Texas-Speed's Avatar
You just need the cam extension harness and the upper cam gear on the timing chain and that converts the cam position from the back of the block (ls1 style) to the front of the motor (ls2 style.). We have the harnesses on the shelf if you need one!
Jon
