LQ4 w/ L92's Problem
Old Aug 21, 2009 | 12:12 AM
thirdgen60's Avatar
Default LQ4 w/ L92's Problem
Well i just recently swapped a set of L92 heads on my LQ4 and i have a problem... my car didnt go any faster in the quarter.
My original setup was this: LQ4 shortblock, stock cast iron heads w/ LS6 springs, comp 222/224 566/568 cam, edelbrock performer intake, holley 770 street avenger carb. The car also has a 2200 stall and 3.50 rear gear. With that setup it went a best of 11.97 @ 113mph.
Then i installed a set of untouched L92's w/ patriot golds, and a gm single plane carb intake. The car now went 12.03 @ 114mph ... so virtually the same.
My guess is that the cam probably isnt right for the heads. Also it only goes through the traps at about 5600rpm so it probably need about a 4.10 gear to bring up to 6500 or so. Im also guessing that changing to such a large port and a single plane, it probably lost to much bottom end. I realize that an LS3 intake and fuel injection would probably gain a lot in the low and midrange but i would like to stick with the carb for now.
Anybody got suggestions or have similar results?
Old Aug 21, 2009 | 12:55 AM
ramdaspadhye's Avatar
the cam definately isn't right for the heads. L92's like a large split duration cam, somethin like a 224/236 high lift (around 600+). Have you milled them any? You prolly wanna mill them .020 or so to bump up your compression.
Old Aug 21, 2009 | 09:51 AM
thirdgen60's Avatar
Yeah i figured that the cam was most likely the main issue and i would like to wait on milling the heads until i build up the short block. I was also concerned that my carb might be borderline small for this setup.
Also, i was wondering if the victor jr. for the L92's has any power advantages over the GM intake or if they are pretty close to the same.
Old Aug 21, 2009 | 12:44 PM
carb should be fine assuming you don't rev past 7k... does it have 4 corner adjust?
Old Aug 21, 2009 | 03:02 PM
nastychevelle's Avatar
talk to pred z about a custom cam
Old Aug 21, 2009 | 06:20 PM
thirdgen60's Avatar
yeah its a 4 corner adjust and i only rev it to about 6700 because im still on a bone stone shortblock.
Old Aug 21, 2009 | 06:29 PM
forcd ind's Avatar
was the preload on the lifters within specs-did the 60' times slow up, also 1/8
Old Aug 24, 2009 | 05:28 PM
thirdgen60's Avatar
I just borrowed a dial indicator from a friend the other day to check the lifter preload but just havnt got it done yet. When i put it together i put them at zero lash and i had to turn them 1 1/4 turn till they were torqued and i read that is about perfect but i will still check it. I lost about a whole tenth on the 60' and i dont remember what the 1/8 was.
Old Aug 24, 2009 | 05:31 PM
jetlag's Avatar
A bigger stall would help you out a lot.... 2200 is almost stock...
Old Aug 24, 2009 | 07:16 PM
thirdgen60's Avatar
yeah a single plane and my 2200 stall dont match to well. It would be great if someone would make a dual plane for these heads because switching to fuel injection and the LS3 intake probably wont be in the budget for a while. I hope that changing the rear gear from a 3.50 to a 4.10 might squeeze another couple tenths out of it.
Old Aug 25, 2009 | 11:44 AM
1CAMWNDR's Avatar
You need a custom cam for that single plane intake also, they like a lot of overlap. Really need to look at a better matched cam and yes, a more aggresive stall will help also.
Old Aug 25, 2009 | 12:07 PM
69LT1Bird's Avatar
You are only about 9.7:1 with the L92 heads on the dished LQ4 pistons.
