ASA cam questions?
With the large exhaust duration, would it be OK to run it without headers for awhile (I know I'd pick some up with headers, but that will come later).
Will it work on stock heads and valves without flycutting the pistons?
Any opinions on this cam.
One a side note, I'd like to see a reverse split cam similar to this like 230/226 with a lift of less than .550 if anyone knows of one. I think with the lower lift (.525) of this cam, valve springs wouldn't be much of an issue.
You'll be fine with stock heads and no headers, but like you said headers will only help.
No, you don't need to flycut pistons with this cam.
02 LS6 springs will be fine with this cam.
