Head swap question!!!!!
I am doing a LQ4 swap into my 01 Camaro and i was wondering what torque specs to go buy. I am swaping a set of 5.3L heads onto my 6.0 block and wanted to know what torque specs to use. Do i just go buy the factory specs for the 6.0 block seeing as how i am still bolting aluminum heads to an iron block.
You got it! Use the OE head bolt spec (20ftlbs plus 90º plus 90º when using the GM bolts).
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
