Gains from a Multiangle valve job
Old Aug 27, 2009 | 11:32 PM
KCS's Avatar
KCS
Moderator
Originally Posted by novaflash2002
the reason for the 70 60 45 30 15 , is the 70degree is almost like a back cut into the head (like a small porting job) it blends the port and the seat together, now the x-tra 15 is to remove a sharp spot out of the cylender (sharp spots create hot spots). as i stated, i have tested my theory more than one time. on average i ran .2 quicker. the reason alote of machinists go with a 3 angle is time. time is money. those extra 2 angles are well worth the hassle. its just like porting, u want smooth transitions not sharp ones.
You can get a cutter designed with more than 3 angles, Sunnen/Newen/etc all do it. I guess if you're doing it with stones, that's a different story. The two extra angles definetly help, not saying they don't, but getting the first 3 right in the first place is a lot better.
Old Aug 28, 2009 | 10:14 AM
novaflash2002's Avatar
o there is no doubt that u can have a decant 3 angle setup. but i will bet money anytime u have a 5 angle that extra time and money wil be worth it in the end. myself personley i like to use the cutter, and finish by hand with the stones, then lap in all of the valves. when i vacuum test the lapped in valves always seal just a tad better.
Old Aug 28, 2009 | 12:09 PM
SLOC5LS6's Avatar
What's the valve job called that TSP does on their LS6 heads?
Old Aug 28, 2009 | 05:07 PM
u will have to talk to them. tsp subcontracts out their machine work to a local company i belive.
Old Aug 28, 2009 | 07:59 PM
KCS's Avatar
KCS
Moderator
Like I said, it's the angles that you have to get right first. If the first 3 suck, two more aren't going to make it much better than if you had them right in the first place. 5 angles just aren't automatically better than 3.
Old Aug 29, 2009 | 01:27 PM
SLOC5LS6's Avatar
Can someone point any TSP reps to this thread
Old Aug 29, 2009 | 05:01 PM
its not really benifical to them.
Old Aug 30, 2009 | 01:46 AM
hammertime's Avatar
If you want to know details on what TSP's or PRC's valve job entails, you should call or PM one of their reps to ask. Most head porters would consider the angles proprietary, along with most other details. The likelyhood of getting any hard data from them posted here is very low.
I'm sure there are several schools of thought on what makes a good breathing cylinder head, so any answer they gave here would likely be the subject of much debate. Asking for key details of a cylinder head is probably the same as asking the Colonel for the secret recipe for KFC - you might actually get the primary ingredients, but getting the knowledge/technique to execute it the same way is still required to get the end result.
Old Aug 30, 2009 | 04:08 AM
Nitroused383's Avatar
I did my own 5 angle valve job, its a lot of work especially if you are using stones and have to gridn them all to size by hand. I spent probably 20 hours in the valve job alone, but I don't do this all the time, I did make it perfect though. Blended the seats and lapped the valves when I was done. Air does not like to turn much more than 15 degrees. Your top cut is pretty critical and it can also help out fuel economy if you get it right. I would like to thank Bret Bauer though because he provided me with all the critical info, helped me along whole way and we matched everything with a cam that performs great.
Edit: The stock gm valve job is a joke. The valve seats are not concentric at all! At a bare minimum everyone should atleast lap there valves in on a stock valve job. Go ahead and check it for yourself, some valves were on touching on one side of the seat.
Old Aug 30, 2009 | 07:03 AM
Eagle Performance's Avatar
A mass production valve job is what it is, it ain't perfect. Add to that what happens to a new casting after many heat cycles, the seats move around. Whether an LS1, LT1, BMW, Harley Davidson, a good 'blueprinted' valve job will always pick up HP. The # of angles have nothing to do with longevity, done properly, more make for a better, smoother transition, more flow. Back cutting the valves works well also.
Old Aug 30, 2009 | 10:47 AM
nitroused, u need a cutting machine lol. your old school like my dad (not a bad thing).
Old Aug 31, 2009 | 11:16 AM
  #32
outlawnova's Avatar
[QUOTE=Nitroused383;12147998]I did my own 5 angle valve job, its a lot of work especially if you are using stones and have to gridn them all to size by hand. I spent probably 20 hours in the valve job alone, but I don't do this all the time, I did make it perfect though. Blended the seats and lapped the valves when I was done. Air does not like to turn much more than 15 degrees. Your top cut is pretty critical and it can also help out fuel economy if you get it right. I would like to thank Bret Bauer though because he provided me with all the critical info, helped me along whole way and we matched everything with a cam that performs great.
How in the hell did you cut that by hand? my **** would be so wack if i did that lol. and in that last port is it me or does it looked cracked?
Old Aug 31, 2009 | 02:14 PM
  #33
I just blended the top cut in by hand with the porting tool. That is just a casting mark, no cracks. This is what I used to do the valve job itself.
Old Aug 31, 2009 | 02:24 PM
  #34
i see some stones hand grinder, and a stone dresser, your good to go.
i have noticed the ls series exhaust seats are some of the hardest i have ever work on.
Old Aug 31, 2009 | 02:29 PM
  #35
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
That's incorrect. 100% of our cylinder head business is done in house (minus the pouring of our aftermarket casting obviously).
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Aug 31, 2009 | 03:10 PM
  #36
just your short blocks are sub-contacted then?
Old Aug 31, 2009 | 08:16 PM
  #37
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
You're basically adding a radiused throat cut to the VJ. That'll always pick up a little bit of flow.
