need help!! car has to much crank case press.
Old Aug 28, 2009 | 08:28 AM
johnster's Avatar
Default need help!! car has to much crank case press.
my car has been driving find, yestr day i was checking things out and it seen that the car had alot of crank case pressure. well 2day it has more pressure. and the car is smoking now.
whats up!! y is it doing this out of the blue?
Old Aug 28, 2009 | 09:32 AM
LS1-450's Avatar
When you remove the oil cap w/car running does oily smoke come out? If so, then it could be failed ring land or hole in piston. If white oily air, then blown head gasket. Hard to say for sure, but if pressurized air comes out w/cap off it's likely one of these issues.
Old Aug 28, 2009 | 11:21 AM
PREDATOR-Z's Avatar
What PCV system do you have? I would check that first.
Old Aug 28, 2009 | 02:48 PM
johnster's Avatar
i have the ls1 pcv, witha new pcv valve,, well it looks like the crank case press had blew out my rear seal caues it looks like its leaking. with the oil cap off ALOT of white smoke is comeing out and white smoke is comeing out the tail pipes to!!!!!
Old Aug 28, 2009 | 02:54 PM
PREDATOR-Z's Avatar
That sounds more like blown gasket, did it overheat or did you spray?
Check radiator level and oil for contamination.
If not that then probably ringland.
Old Aug 28, 2009 | 03:00 PM
johnster's Avatar
never been sprayed. it didnt over heat, so it dont sound good!!!
Old Aug 28, 2009 | 03:27 PM
johnster's Avatar
maybe this will help, the white oil started comen out with the oil cap off, just alittle at 1st but now its really comeing out and the car is smokeing out the tail pipes, at 1st it wasnt smoken out the tail pipes. if it was a head gasket the car would have started smoken rite away???? yes or no
Old Aug 28, 2009 | 05:02 PM
NHRAFORMULA00's Avatar
Check your radiator to see if the level is low.If it is and it is not leaking then it is a blown head gasket,coolant is being sucked past the blown gasket into the cylinder,creating the white smoke.Also check you oil to see if is milk chocolate looking at all.
Old Aug 28, 2009 | 06:03 PM
LS1-450's Avatar
Time to pull the heads & have a look.
Old Aug 28, 2009 | 06:25 PM
01ssreda4's Avatar
doesn't sound good but its fixable.
Old Aug 28, 2009 | 07:00 PM
johnster's Avatar
thanks guys guess ill pull the heads
