Cam. Should I do it?
also, what is your idea of a fortune? is $2,000 too much to spend on a H/C setup for you?
heres some questions you need to answer before we can really help you:
1.)what are your power goals for the car?
2.)how do you want it to drive? (like, is this you DD or a weekend car?)
3.)what are your track goals (if any)?
4.)how much are you willing/ABLE to spend? <---thats the biggy
i dont think 145k is too much for a H/C package. with that said, if i was doing a H/C on that high mileage engine, id use it as an excuse to replace alot of stuff in the motor. basically a rebuild, but not complete.
another option is buying a new motor. if you have deep enough pockets, why not get a fresh motor? i know TSP's 370ci is even cheaper than their 347ci, adn that would allow you (because its a 6.0 block) to use L92 heads or even go up to a 408ci if you want a stroker later on. but its not just TSP, their are plenty of sponsors here that can build you a lower cube motor for cheap. if you are going to tear the whole motor down, and rebuild with new rods and pistons, bearings etc., id go the new motor route, as it can be very expensive rebuilding depending on where you go.
Thats not entirely true. First thing i would recomend is to get a leakdown test and compression test. If it passes that then you would be ok with doing Heads and Cam as long as you dont go with a high compression setup. Something a little more modest like a 230 cam and LS6 heads would not be too hard on your motor.
There have been a couple guys that have run 200,000 miles on camonly or H/C setups but none that i know of used a donkey dick cam or high compression heads. So you can do it, but you need to be realistic about the motors capabilities.
That being said you should also look into replacing lifters, oil pump, timing chain, and every gasket you can get your hands on.
One more thing. If you DO go with a large cam (high 230 low 240) You would be waisting your time and money if you dont upgrade your intake because that LS1 will not be able to flow well enough in the high RPMs to feed abig cam.
You would be looking at around 380 to 410rwhp. And it would have a lot of tq.
