stroke or not to stroke
Old Sep 2, 2009 | 02:35 PM
NemeSS's Avatar
Originally Posted by z28mccrory
Sell your motor as-is and pick up a 6.0 Truck shortblock for cheap.
For the money you would spend on a 4" crank to make a 383, you could find a set of nice used heads.
A 6.0 truck motor is a 4" bore, which will breath better than the 3.9" LS1 once you get decent heads.
+1
the stock 317 heads are same thing as ls2 heads, but just have larger chamber. unless u plan on max effort n/a there is really no need for p/p heads. the 6.0 can be machined .060 over. with stock crank = 375ci
and with the 317 heads milled and moderate matched cam it will approach 500bhp.
Old Sep 2, 2009 | 02:37 PM
z28mccrory's Avatar
Originally Posted by NemeSS
+1
Im glad someone else agrees, lol.
Im so sick of hearing everyone preach "yeah do a stroker" when they aren't standing back and looking at the other options.
Old Sep 2, 2009 | 02:58 PM
NemeSS's Avatar
<<< 490rw 375ci with non ported but upgraded with 2.02 rev valves 243 heads,vj,valve throat,bowl blend 10.8:1scr
cast pistons, stock rods,arp rod bolts, stock crank. ls6 intake, 85mm 3 bolt tb. sd tune. udp.lt,3in.bullet exhaust. lsk lobes cam.etc. 7k rpm, m6
Old Sep 2, 2009 | 04:52 PM
99Ls1fever's Avatar
Originally Posted by 99blancoSS
Whats the cost of that s/c setup and fuel system?
You can make great power with FI, but don't forget to add that in when your comparing costs.
I got the G Trim Head Unit for $800 and I bought all the piping and misc parts off Coopdog for $800. So I have 1600 in the G Trim Unit.
I spent $200 total for both (2) Walbro 255lph Fuel Pumps from Texas Speed. I spent $75 on a Aeromotive Fuel Pressure Regulator. Injectors came with the misc from Coopdog.
So that is the total I have in these parts.
OP, I would build a 347. There are amazing deals online and off ebay for all kinds of different forced induction methods. I have had three different forced induction kits and systems. I have found everyone for under 2500 dollars. I found most of these deals on ls1tech. STS, Procharger, Vortech. I hae sold all these systems except the Vortech that I currently am running on my Z28. I highly reccommend savings your money and just building a Forged 347. There are NUMEROUS SICK 347 Builds. Best of luck
Old Sep 2, 2009 | 05:36 PM
SOMbitch's Avatar
I will stroke the LS1 for two reasons:
1. I don't want the extra weight over the nose as I am a spirited driver at times and love hard cornering.
2. I can pretty easily make 470ish (10's) on the 3.9" bore and stay in my budget just running my current heads.
If it was a max effort build damn straight I'd go bigger bore. It's all about what you want out of the car....
Old Sep 2, 2009 | 07:51 PM
z28mccrory's Avatar
You could use an LS2 block.
If you sell your LS1 shortblock while its still in good working order, it would offset a good chunk of the cost.
Im using 5.3 heads on my 4" bore motor (noticed thats what you had)
Old Sep 2, 2009 | 08:08 PM
1sick'98WS6's Avatar
stroke it stroke it...
Old Sep 2, 2009 | 08:35 PM
will01's Avatar
OP, you should have added a poll. Out of the 27 posts you have 19 votes (each vote only counted once cannot vote more than once). Here are the results so far:
11 votes for 383
3 votes for forged 347 (I am 1 of 3, add a good FI set-up and you have lots of power and a mean daily drive. This is the set-up I drive over 90 miles each day)
3 votes for 370 (truck motor)
2 votes for new SDPC crate engine
1 vote for 402
So what is your choice?
Old Sep 2, 2009 | 08:59 PM
SOMbitch's Avatar
I agree with everything you say and if I was not working within a budget I would go 402 or dream big and do a LS7. But a good 383 combo will put me in the 10's and if I want more a 150 shot should hit 9's. I have 3 kids and a child support payment so budget is a big part of my decision but I think I would be happy with 470ish....For a while anyway...LOL.
Can you give me the rest of your motor specs and what it put down BTW?????
And to the OP... If all you are chasing is HP and you can swing it go bigger bore with some L92's with a WELL matched cam (the key) and you will prolly get the most power for your dollar of about any LSx combo IMO.....Stroke that b!tch and you will see INSANE bottom end torque
Old Sep 2, 2009 | 11:30 PM
Hypnotic's Avatar
Originally Posted by kenp
I would buy one of the new LS6 crates available for under $2800 from SDPC.
I can't find this anywhere? They have an LS1 for $4,800...
Old Sep 3, 2009 | 10:04 AM
99Ls1fever's Avatar
2800 Seems Pretty Cheap for a LS6??????
Old Sep 3, 2009 | 10:21 AM
  #32
SOMbitch's Avatar
It was in the sponsor sales section i think earlier this week......
Old Sep 3, 2009 | 11:00 AM
  #33
99blancoSS's Avatar
That's pretty good, most people spend between 5500-7000 for their d1 s/c setup with inter-cooler and then have to add in a meth kit and eventual pulley system to keep belts from slipping . Personally I like n/a and the more cubes the better. I suppose if I was looking for a FI build I'd go with and LSX 434 and twins.
Old Sep 3, 2009 | 01:03 PM
  #34
99Ls1fever's Avatar
That Sounds Like party in a bag with the LSX and the TWINS!!! I never ran a meth kit on any of my kits so far and have never had any problems with them.
I agree S/C ers are usally really expensive. I think if people stay patient and cruise multiple boards then you're bound to find something. Even if it is a P1SC and you have it upgraded in the future to a d1sc. I am not a big STS supporter and dont really reccomend them to anyone. But the do make some imprssive dyno numbers and offer a smaller price for most people on the boards. I saw 10lbs on mine w stock everything minus cats gutted and put down 48x something.
I think F/I can be cheaper than people think if they take there time on builds and piece kits together.
I do think that if someone is going to run TWINS then it doesnt really matter the displacement. You can always just make more boost and those turbo setups can just keep cranking up more boost anyways. I would be curious to see how much differance there would be between a 434 LSX with Twins and a Forged 347 with Twins would be???
I mean realsticly if DUMB people dont chime in with stupid comments.
What would be the differance? Either setup CORECTLY BUILT could run upwards of 1,000 hp. At this point you would be into theory and there is no realistic point of having this much HP unless you are John Force.
I am Positive I could build a Twins Setup for mine and produce upwards of 9xx numbers. Tiago switching out his turbo's accomplished this at like 8lbs on twins. And, then in his new setup 1,xxx something.
The Twins are sick, I hope you build one of these setups. It sure would be an amazing build and fun just to say you did it. Tiago is the only one I know that has done a lsx twins build that I KNOW. Cant speak for anyone else.
Old Sep 3, 2009 | 02:28 PM
  #35
NemeSS's Avatar
for 4500$ u can also get a 427 shorblock
Old Sep 3, 2009 | 03:54 PM
  #36
99blancoSS's Avatar
I've got a HKE 408 for $3600 right now as well but we normally dont run sales on engines. Just a customer engine that could not be paid for.
Old Sep 4, 2009 | 07:00 AM
  #37
The Alchemist's Avatar
UNDER PRESSURE MOD
I'm guessing that's an iron block?? I want to keep the front end as light as possible, so I want to go with a 400+ cube aluminum motor. I've been keeping my eyes open for a good shortblock, fully balanced motor for less than $4000, but it has to be AL.
Old Sep 4, 2009 | 08:19 AM
  #38
FastKat's Avatar
I had a low compression 347 shortblock with forged rods and pistons built for me with the hopes of running a turbo or supercharger, but the price of forced induction is very high and I still haven't finished it. In hindsight, I wish I would have paid the extra $1,000 (cost at the time) and got the 383 shortblock. The longer stroke is doing to give you more torque all over the powerband and will provide a great foundation to continue to build your motor.
Old Sep 21, 2009 | 08:38 PM
  #39
01screaminchickin's Avatar
To Stroke, 383 forged bottom end flat top pistons with -6cc valve reliefs arrived today, gonna finish tear down and prep for machine shop, plan on setting up the bottom end after the machine shop is done so i can get all my measurements so i can calculate what size cumbustion chamber i need to get desired compression, WHATS THE HIGHEST COMPRESSION I CAN RUN (without fighting detnation) WITH 93 GAS AND ALIL BOOSTER?
Old Sep 21, 2009 | 09:11 PM
  #40
shawn_c992001's Avatar
If it were me, forged bottom end, rods and pistons only, but don't forget the ARP rod bolts.
This winter I'm going to throw on a set of 317's (P&P of course), Thunder's LS2 Cheater cam, LS7 lifters, pushrods, ARP Rod bolts, Intercooler(E-Bay), Walbro 255, and a 50hp shot through the turbo. I'm just going for 600rwhp though.
