Trick Flow prices?
Old Sep 3, 2009 | 11:15 AM
blackhawk0251's Avatar
Default Trick Flow prices?
I was actually kind of wondering a few things..my mods are in my sig. I was wondering what would be suitable for me as far as street/strip goes.
Thanks in advanced.
Old Sep 3, 2009 | 11:25 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We have them in stock I believe. The Trick flow will require roller rockers & a upgrade to the springs to run the camshaft you have in your sig.
Shoot me a pm if you need pricing.
You could also consider the PRC 215cc heads. They feature .700" lift PRC springs & will use stock or aftermarket rockers. If you order the PRC heads with no springs (so you can reuse yours) you'd be right at $2,000 out the door!!!
http://www.texas-speed.com/shop/item...d=993&catid=40
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
