question/problem
Old Sep 6, 2009 | 06:34 PM
Lances02ss's Avatar
Default question/problem
i got my 408 in the car and at first i disconnected fuel to prime the oil pump then i busted it off it knocked bad for the 5 seconds i let it run i pull the valve cover off and no oil is n the heads at all i pulled the hardened push rod out and there is oil at the bottom but none is coming thru rods are new hell everything is new how long am i supposed to run it and do i actually have to bust it off for awhile for the oil to make it up idk... im registering 45 psi so i know the crank has oil anyways do i have to let it run for awhile plz help
Old Sep 6, 2009 | 07:14 PM
1sic03x's Avatar
so there is no oil coming through the push rods? if they are new, try cleaning them with a solvent then blow compressed air through the push rods, there could be debris in them keeping the oil from flowing to the top of the rods.
Old Sep 6, 2009 | 09:52 PM
Lances02ss's Avatar
ok oil started to come out the car ran for about 5 to 10 mins how is it suppose to run if its pretty much a dry start
Old Sep 7, 2009 | 03:47 PM
Lances02ss's Avatar
still having the problem anyone got anymore suggestions
