New pushrods for ls6 cam?
Old Nov 28, 2003 | 10:39 AM
Todd@AZPowerAndSound's Avatar
Default New pushrods for ls6 cam?
Is it necessary to change pushrods when installing the LS6 cam? Personally, I dont believe so, but would like to know if Im wrong.
Old Nov 28, 2003 | 11:16 AM
LS1x2's Avatar
Formerly 4mulaJoe
If the base circle of the ls6 cam is the same as what you have in there then you shouldn't have too. This also assumes the springs are installed at the same height.
Old Nov 28, 2003 | 12:40 PM
Larry's Avatar
Don't know what year your LS1 is but if it's a 98 then you will need .016 shorter push rods to achieve the same lifter preload. The 98 base circle is 1.552 diameter. The 01 LS6 cam has a 1.520 diameter base circle. I installed this cam in mine with my stock length 98 pushrods and got too much lifter noise. My current cam is a Comp 218/218 with a 1.540 BC. Lifter noise is acceptable. Had I milled my heads .015 then I would have had stock lifter preload.
Be careful with some of the aftermaket cams. Make sure you know the BS before buying the cam or plan to modify.
4mulaJoe,
What does the spring installed height have to do with push rod length?
Old Nov 28, 2003 | 12:42 PM
00ls1 motor, 02ls6 cam
Old Nov 28, 2003 | 01:28 PM
AZ Power & Sound's Avatar
bling bling... engine is coming apart tonight
Old Nov 28, 2003 | 01:42 PM
Larry's Avatar
From what I have read the 01 and 02 models have the same BC. You should be fine but I sure would measure the BC before I installed it just for insurance.
Don't know about springs. I would sure check on them too!
